Base tune help
AWD_HATCH
Base tune help
Post by AWD_HATCH »
Hello I'm in need of some help need a base tune for a k20z3 turbo 4 bar map sensor and bosch 2000 injectors. Could someone please help me with a base map. Thanks in advance
CalibratEd
Re: Base tune help
Post by CalibratEd »
Welcome to the forum,
Do you plan on getting it professionally tuned? Perhaps you can reach out to your tuner for a basemap to get you started. Turbo basemaps are not as easy to come by as they take some work. If you plan to create a base map of your own I don't mind looking it over.
- Ed
Instagram: calibrated.tuning
AWD_HATCH
Re: Base tune help
Post by AWD_HATCH »
Plan is to have it dyno tune but tuner is out for a couple of weeks. I was thinking of using my last map and which had 1250cc injectors and just richen the tune but I don't really know what I'm doing lol... Those injectors went out and started leaking when tested so figured I would just buy bigger injectors and start upgrading the fuel pump as I'm trying to go E85. I can upload the last tune I had if that would help you.
CalibratEd
Re: Base tune help
I suggest you use your previous tune. Change the injector data and dial in the fuel and timing to get it running safe.
-Ed
hpmx18
Re: Base tune help
Post by hpmx18 »
i have a tune i did last year that should help you get started till you get to dyno il post it in the AM when i get to my laptop
LGMotoring
IG:Lgmotoring_official
Lgmotoring.com
AWD_HATCH
Re: Base tune help
Post by AWD_HATCH »
That's awesome thanks
