Map Sensor reading frozen, car goes lean with any gas
s2kNate
Post by s2kNate »
K24a2 swapped s2000
- K-Pro serial number: 65641
- version 4.5.8.0
- ECU part number: 37820-PNF-A03 serial number: 2091-307155
- s2000 intake manifold w/stock s2000 map sensor, rywire wiring harness
- K-pro purchased last month from clm motorsports
I'm just buttoning up my K swap and the car idles but any gas at all causes it to go lean/sputter/die. When datalogging the Map reading seems "frozen", it gets an initial reading of usually around 17.5 psi and never changes. I tried it with the map sensor removed and it was around 11 psi. I swapped MAP sensors with my other S2000 and it was no different. I also checked the wiring and the ground is good, getting 5 volts power, and 1.2 volts from the signal wire which all seem to check out. In Parameters "Stock MAP Sensor" is selected which I believe should be correct. I've attached a datalog and the calibration. I'm out of ideas on what I can do next, is the ecu bad?
Re: Map Sensor reading frozen, car goes lean with any gas
Have you tried the ECU on a known working vehicle?
s2kNate
Post by s2kNate »
I don't know anyone with an ECU to try. I did check the continuity with a multimeter from the sensor plug to the ECU plug and it all checked out.
You may need to discuss the issue with Rywire since the did the harness.
s2kNate
Post by s2kNate »
I ended up figuring it out. I de-pinned the wiring off of my old s2000 harness and pinned it into the Rywire harness and everything works as it should now.
