What ecu what hondata questions
angelabarriga
Post by angelabarriga »
I have a 1992 integra b20 I'm confusing myself as to what ecu is gmerge fruitsoing to plug and play then what hondata can I put base maps on from a desktop computer or is a laptop100% required for this to function properly to run a base map
Re: What ecu what hondata questions
To use a Hondata system, you will need a compatible OBD1 ECU from the list at https://www.hondata.com/tech-obdi-ecu-reference. You can then use the Hondata s300 ( https://www.hondata.com/index.php?_route_=s300 ).
You will need a Windows based laptop to be able to tune this.
