Basemap so agresive?
metuskale
Post by metuskale »
Hello everybody,
After a few months not using the car very much I finally installed the eventuri intake and turbo tube and changed the calibration basemap accordingly.
I then did a launch in 3rd gear to redline and I noticied a few things I find strange:
Here is a point with full open throttle where the fuel pump reaches 100% and the MAP read is 2,92. I imagine that reaching "almost" 100% fuel pump could be "normal" because of the 100% throttle pedal but reaching that point is dangerous because it may no supply enough fuel.
About the MAP reading, I imagine this 2,92 bar is absolute pressure, the run was made in a place where the pressure is about 1 bar so it makes the turbo output about 1,9 bar aprox, isn't it so much?
Can someone please point me in the right direction? I don't mind losing a few CV or NM to be safer with this tune.
Re: Basemap so agresive?
IF you are maxing out the fuel pump then you need to lower the air charge so it does not max out.
metuskale
Post by metuskale »
Yes, I thought it might need some adjustments.
How can I do it? I am still learning and I wouldn't like to break anything.
metuskale
Post by metuskale »
Yes I did, I understand I have to reduce the amount in the fuel tables but TBH I have no idea on how to do it, should I reduce all values for let's say a 5%?
Or only some of them?
Thank you
metuskale
Post by metuskale »
Might I reduce the values about 10% in this table?
Would that be enough?
you can try that but may need to reduce further.
