05/06 RSX with k20a2
Kreetoes
Post by Kreetoes »
Get crank but no start. I NEED HELP YALL
Re: 05/06 RSX with k20a2
Is the immobilizer enabled or disabled in the calibration?
Kreetoes
Post by Kreetoes »
Immobilizer is disabled.
For more context, I hade the 05 base harness with the new engine in and still had the same problem. Car started with the base ecu but no the kpro. I was then told to switch to the engine harness for the actual engine. Here I am no with the same problem of getting a crank with no start. I have all the right sensors and modified the harness to what needed to be modified. Could it just be that i have the wrong settings on my kpro?
Kreetoes
Post by Kreetoes »
NOTE: I have the conversion harness for the kpro
What is the serial number that is on the K-Pro bard inside the ECU?
Kreetoes
Post by Kreetoes »
Serial Number on ECU is 37820-PND-AO5
Software Version 4.5.9.0
I need the serial number on the K-Pro board inside the ECU.
Kreetoes
Post by Kreetoes »
According to our records this K-Pro was not modified for use with an 05-06 RSX and was not sold with an adapter harness.
Kreetoes
Post by Kreetoes »
Should I contact to send it over to get it modified and would I need a new conversion harness?
Kreetoes
Post by Kreetoes »
Also is there a copy of the initial form that i sent when ordering the kpro. If this is case, how come I was able to run the K-pro when i had my K20A3 still in the vehicle.
Where did you get the adapter harness?
Post a picture of it.
Kreetoes
Post by Kreetoes »
My coworker had one. Figured it would save me money since he had no use for it anymore.
That will not work properly as the ECU was not modified for use in an 05-06 RSX.
The form you need to use to get the ECU modified and purchase the adapter harness can be found at: http://hondata.com/downloads/05-06_rsx_ ... e_form.pdf
Kreetoes
Post by Kreetoes »
Okay thank you for your help!
