Guide Request: Speed Density Starting Fuel
Water
Post by Water »
Would anyone be so kind enough to share how they approach starting and idle fuel for speed density based calibrations?
Background to why I’m asking:
I’ve made a custom turbo kit. 1,000cc injectors, dw65c. Gt3076. Nothing radical, on a stock k24z7, original engine in vehicle.
I’ve already dialed in an AFM based calibration while the engine had 1,000 cc injectors, stock intake, no turbo. Then set my cruising AFR to 15, just to explore a few slight changes and analyze if this helps fuel economy (it did slightly), and overall “research” purposes. My cats are fine too.
But when researching and comparing speed density calibrations for similar setups, I could not understand the proper method of approach. If I got it to fire, it would immediately shut off after about two seconds.
This isn’t a mechanical or electrical issue - when I upload the previous AFM calibration I made, it starts and idles just fine.
So I’m kindly asking any expert to chime in so any lurkers like myself can have a more in depth understanding of this procedure as the hondata help tab is rather vague for the novice tuner.
Also, I do plan on getting a professional dyno tune, but I’d like to know exactly what’s happening while it’s happening.
If possible, follow a what changes and why format for each calibration setting relevant to this phase of tuning. A lot of other forums just mention overall trim and cranking trim without a solid explanation of how these settings affect the engine mechanically/physically with respect to time (for startup).
- Brand
Water
Re: Guide Request: Speed Density Starting Fuel
Post by Water »
Alright so to make this thread less of a dead end for future viewers-
To tune start fuel for speed density you must ensure the injector dead times are absolutely correct. It is possible that the injector manufacturer dead times are inaccurate, this has happened to me before.
Injector dead times play a vital role in cranking, the built in ecu logic must pulse precisely for optimal starting.
By increasing fuel in increments of 5%, cranking fuel can be dialed in. The hondata help guide is NOT vague, all of the information is accurate and complete.
- Brand
