Active handling assist and FlashPro
EPSi2FKR
Post by EPSi2FKR »
Is there any way to disable the active handling assist with the FlashPro in the FK8? The active handling control is causing catastrophic pad drag on turn in at the track. There is a “pedal dance” that puts the car into maintenance mode that turns it off AND SOLVED THE ISSUE but that can only be done in sport mode. The long press of the VSA in R+ mode does not disable the AHA and did not solve the issue. Power and suspension wise I need to be in R+ mode for the track. Also, is there a power difference between Sport and R+ modes?
Thank you for your time and any help
Re: Active handling assist and FlashPro
Hondata has no way of controlling this.
You can tune the torque tables for Sport and R modes to be the same.
