STUCK HELP !!
Kartikh12
STUCK HELP !!
Post by Kartikh12 »
Car : 2021 honda civic type r
Hi just purchased the flashpro mini, my hondas ecu was preciously taken out sent away and a tune loaded onto it and therefore its jailbroken, once i plug my hondata in and try upload a calibration it keeps giving error code 0x04 check obd2 plug address 16 then my ecu goes into safe mode and i cant do anything except restore to factory ecu, i have done it back and forth like 10 times now and still nothing. I have lost the tune that was on the honda also :( what can i do to fix this all i wanted extra was the full throtle shift, no drone? Throtle responce, launch controll and anti lag.
Re: STUCK HELP !!
Who did the jailbreak? What is the FlashPro serial?
Kartikh12
Re: STUCK HELP !!
Post by Kartikh12 »
Im not to sure who did the jailbreak, all i was told was that my ecu has been sent away to get jailbroken and a tune loaded onto it.
Flashpro serial: FP-CTR-INT-372094
When you plug the flashpro in, it detects everything fine.
Jaikbreak status says "unkown" but theres a green tick for everything at the bottom when on the calibrartion page
Also the calibration loads like 3/4 of the way then fails error 0x04 always then ecu goes into recovery. And then restore ecu to factory works fine. Ive done it 10x by now but still no changes in anything.
Kartikh12
Re: STUCK HELP !!
Post by Kartikh12 »
Im in newzealand also. And i click the australia 2017-2021 option when adding new calibration since they are closer to us country choice wise
Re: STUCK HELP !!
It sounds like the ECU has not been jailbroken. You must return it to stock from the online menu, then the ECU will have to be jailbroken.
Re: STUCK HELP !!
Kartikh12
Re: STUCK HELP !!
Post by Kartikh12 »
Yes ive tried returning it to stock a handfull of times but it is still not letting me click the jailbreak button on the jailbreak tab 😌
Re: STUCK HELP !!
Did you purchase an instant jailbreak?
Kartikh12
Re: STUCK HELP !!
Post by Kartikh12 »
No i did not. Am i ment to purchause that seperate ?
Re: STUCK HELP !!
yes, you must purchase it and do it yourself.
https://hondata.com/instant-jailbreak?r ... =jailbreak
Kartikh12
Re: STUCK HELP !!
Post by Kartikh12 »
Will the instant jailbreak work on the 2021 model or do i have to also buy that other jailbreak thing for $75 ?
Re: STUCK HELP !!
IF it is a 21 you also need the jailbreaker.
