Hondata Coil-on-Plug Conversion Compatibility with P28-OBD2A ECM
Re: Hondata Coil-on-Plug Conversion Compatibility with P28-OBD2A ECM
Are you actually using an s300 in this?
Typically, you need to have the car running properly with an OEM distributor before trying to swap over to the CPR.
