boost control works during test but not on dyno
kseriescivic
Post by kseriescivic »
I'm on the dyno right now and can't get the boost solenoid to work during a pull. If I test outputs and hit the solenoid it works fine. I data logged a pull and PWM goes from 0% to 1% and thats it.
I have everything wired correctly from the solenoid, switch power and A11. my wastegate lines are on right, left port to top of gate and right port T'd to compressor housing and bottom of gate
Re: boost control works during test but not on dyno
Boost control is not enabled in the calibration.
kseriescivic
I think I just disabled it before I saved the map and posted it. We tried fixed duty and gear based duty at 50% and nothing would happen.
I’ll try again today and post the cal with datalog
kseriescivic
kseriescivic
Here is a pull with boost control enabled and the cal also
25% duty on fixed DC and PWM only hits 1%
kseriescivic
Is it possible I have a corrupt tune file?
Psot a picture of the inside of your ECU.
Does the ECU have the components for boost control?
