Help, Just did a K24 swap and getting knock sensor code
Tchang401
Post by Tchang401 »
Hello all, I just did a RBB3 jdm K24 swap in my 8th gen and I'm getting a P0325 code for knock. I have a brand new ktuned knock sensor in and I checked my wiring to see if im getting signal and I am. When I check on the hondata app on my phone is saying the same thing. Knock sensor 1 circuit malfunction. Any help would be appreciated. I need to get rid of this check engine light so I can get it tuned. It's got, RBC manifold, skunk2 cold air, skunk2 alpha headers, j35 throttle body and I ported the mani to match, 410cc rdx injectors, 50 degree vtc. Thanks in advance.
CalibratEd
Re: Help, Just did a K24 swap and getting knock sensor code
Post by CalibratEd »
Double check the wiring and the pins on the connectors to make sure they are making proper contact. I also suggest to install the stock knock sensor just in case the one you are running is bad.
-Ed
Instagram: calibrated.tuning
Akrkwk310
Post by Akrkwk310 »
I am having the same issue, you must use the the knock sensor from your original car. Even if your engine is k24, because they have different harness connector I heard
