1996 turbo DX
96DX
1996 turbo DX
Post by 96DX »
Hi, i have a 96 dx, which is in the process of going turbo. now, i need to know what engine management will work for my car...which one should i go with? is there a pre-tuned option i can go with? or better yet...which hondata application will work for my car and setup? im running a t3/t4 turbo if that matters, at about 6-8psi. (when finished.) would this application be all that i would need or are there other things i would need to get? thanks in advance for any info!
You can use either the s100 or s200 depending on what options you want. It will need to be tuned on the dyno by one of the Hondata dealers listed on the Hondata website.
