kpro v4 no showing a vss input on display screen
corlon
Post by corlon »
hello, i am unable to get the vss input to change on the display screen. the vss shows changes in the graph screen and on the sensor screen. the vss input on the sensor screen does not change.is this supposed to show changes on the display screen? i have tried 2 different ecus with the same result. here is the calibration and a datalog from both ecus. please let me know if any other information is needed. thank you.
Re: kpro v4 no showing a vss input on display screen
It is showing correctly in all locations. Try using a different display or edit the display you are using.
