Hi,
I wonder If anyone can help with a base file to get my car up and running safely. Engine is a stock K24a bottom end, stock K20Z4 head with stock 50 degree VTC and cams. 440cc injectors.
Will I be safe running a stock FN2 tune and changing the injector parameters?
Any help would be greatly appreciated.
Thanks in advance
Sean
K24 Frank - K24a with K20Z4 (FN2) Head - 50 Degree VTC - 440cc Injectors
seaneb2003
- CalibratEd
- Contact:
Re: K24 Frank - K24a with K20Z4 (FN2) Head - 50 Degree VTC - 440cc Injectors
It may need some adjustments. Datalog the car after you have made the injector changes. Post the calibration file and a datalog. I can take a look at it and let you know how the car is running.
- Ed
- Ed
Instagram: calibrated.tuning
seaneb2003
Thank you Ed. Got a few bits to finish off with it still at the moment but as soon as its ready ill get a log and post it. Much appreciated!
Sean
Sean
- CalibratEd
- Contact:
seaneb2003 wrote: Fri Jun 21, 2024 3:40 pm Thank you Ed. Got a few bits to finish off with it still at the moment but as soon as its ready ill get a log and post it. Much appreciated!
Sean
No problem.
-Ed
