cruise control
ooolEXILElooo
cruise control
Post by ooolEXILElooo »
Hi, I am having trouble with cruise control. When using flashpro on my fk8, if I turn on cruise control and click the button to accelerate, the cruise control starts to accelerate but then quickly disengaged. it doesn't turn off completely, just disengages. Also sometimes when I just simply click "set" on the CC it doesn't engage and sometimes it does. at the time I was running "remove factory boost limits", "catalyst purge stock", "pump gas (10% ethanol)", "stock fuel system", "stock injectors", "stock intake", "stock reviews limiter", "remove P0101 & P0103 error", "improved response full power 1st 2nd", "traction control aggressive launch", "increase turbocharger boost limit", "increase turbocharger pressure ratio limit".
is there any reason for any of these things to make my cruise control from functioning correctly? Please help.
Re: cruise control
What is your FlashPro serial number?
ooolEXILElooo
Re: cruise control
Spunkster wrote: Thu Jun 20, 2024 9:04 am What is your FlashPro serial number?
SN is FP-CTR-FK8-354627
ooolEXILElooo
Re: cruise control
Also speedometer is adjusted for my 18 inch rims. That's set to -5.04%
Re: cruise control
ooolEXILElooo
Re: cruise control
Spunkster wrote: Thu Jun 20, 2024 4:13 pm With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
I just now did a datalog if that helps?
ooolEXILElooo
Re: cruise control
Hey, I just put the "speed adjustment" back to 0 and my Cruise control works again just fine. So you guys might wanna fix that issue in an update. Like I said, I can send a datalog of what was happening if it helps at all.
Re: cruise control
You still have not sent the feedback as requested.
ooolEXILElooo
Re: cruise control
Spunkster wrote: Thu Jun 20, 2024 5:00 pm You still have not sent the feedback as requested.
Ok I just sent it under Software Bug
ooolEXILElooo
Re: cruise control
So sense I sent that thing in how you asked me to, will I be contacted about the bug and if they can fix it or if they even plan to?
Re: cruise control
Post your calibration and a datalog showing when this is happening.
ooolEXILElooo
Re: cruise control
Spunkster wrote: Fri Jun 28, 2024 11:23 am Post your calibration and a datalog showing when this is happening.
Here is the datalog
Re: cruise control
Post the calibration as well
ooolEXILElooo
Re: cruise control
Spunkster wrote: Wed Jul 17, 2024 8:52 am Post the calibration as well
How do I do that?
ooolEXILElooo
Re: cruise control
I figured it out. Here is the calibration.
