car cuts off with throttle blip on idle running super rich
cartereg
Post by cartereg »
am dealing with a issue with my k 24a turbo.
the car came to stop one night doing a pull and just cut off. unfortunately i didn't have a data log setup when that happened. i got the car home and tried to start it and it would crank for second and die with the ecu hooked up to k-pro i noticed that the map sensor was reading a low value i swapped the map sensor out and now the car idles steady but is super rich and when i press the gas it will die out instantly.
idles hit gas struggleing to idle then cuts out.kdl
Re: car cuts off with throttle blip on idle running super rich
The MAP sensor does not appear to be reading correctly as it is the same at all times.
