SManager 2.8.7
SManager 2.8.7
SManager V2.8.7 (29 Jun 2024)
•[S300 V3] Firmware version 22
•[S300 V3] Improved onboard datalogging
•[S300 V3] Improved onboard calibration storage
This release fixes any problems when on board datalogging and laptop datalogging and then uploading a calibration at the same time.
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
yball26
Re: SManager 2.8.7 datalog issue
Post by yball26 »
]Hello, I have problems with the data log of my track pass, they had always worked quite well, sometimes I had an error in the data but now everything is wrong, the miles per hour says 400mph and crazy things, if you have a way to fix the data or download again I tried two different laptops and the same error still occurs, it's Windows 10 in case you ask me. Thank you, I look forward to your prompt response.
Re: SManager 2.8.7
yball26
Re: SManager 2.8.7
Post by yball26 »
59843
Re: SManager 2.8.7
Are you datalogging with the laptop, or are you using on-board datalogging?
yball26
Re: SManager 2.8.7
Post by yball26 »
on board
yball26
Re: SManager 2.8.7
Post by yball26 »
I never had any problems with the laptop.
Re: SManager 2.8.7
spAdam
Re: SManager 2.8.7
Post by spAdam »
Any chance that PLX protocol was dropped from the digital inputs in the latest firmware?
I haven’t used my S300 in almost a year and I updated everything before I plugged up. I can’t get the digital inputs from my sm-afr. I’ve confirmed wiring is solid and continuity is good, the PLX gauge is working off of the Y-connector so I know the sm-afr is broadcasting. Worked flawlessly in the past.
Any ideas?
Re: SManager 2.8.7
No changes have been made in that area.
spAdam
Re: SManager 2.8.7
Post by spAdam »
Copy, thanks. I’ll keep digging.
wanganracing93
Re: SManager 2.8.7
Post by wanganracing93 »
Hondata wrote: Mon Jul 01, 2024 8:37 am SManager V2.8.7 (29 Jun 2024)
Download here
Hi team, I’m currently having issues with this, im getting “out of date” even though I downloaded the most recent software out the website. Unable to connect to the laptop. Attached is image of error.
Please help I just bought this car and it came with an s300 and I’m trying to see what it’s running on. Thanks in advanced.
Re: SManager 2.8.7
What computer, processor and version of Windows are you using?
wanganracing93
Re: SManager 2.8.7
attached is all the info. thanks for the response
Re: SManager 2.8.7
Go to the help menu and click on about and take a screenshot and post it here.
