K24a1 correct Kpro ecu
Ventolin5
Post by Ventolin5 »
Hello all, I have just purchased a 94 civic (eg) with a k24A1 and a APG6 (03-06 accord) 5spd trans. I need to get a Kpro and was told a prb Kpro v4 would work out great. I wanted to check and make sure this was the correct ecu setup to run.
Any help would be greatly appreciated. Thanks!
Re: K24a1 correct Kpro ecu
What is the full ECU part number?
Ventolin5
Post by Ventolin5 »
I got a PND… part number is 37820-PND-A53.
Having a hard time finding a correct base map.
Yes, that ECU can be used. Details can be found at: https://hondata.com/tech-alternative-ecu-engine-swap
