Hi,
I have a 06 Honda civic Si with a k&N SRI. Other than that, the power is all stock like stock header and exhaust etc.
I see Hondata offers a k&N SRI base map. How safe is it to run that base map without a ETune or dyno tune for track days?
I take my civic si to the race track for track days and I do consistently run the engine at 6k ish to 8k ish rpm for the whole sessions and do push the car to its limit.
Would I break my engine if I use a Hondata k&N SRI base map?
Thanks!
How safe to redline a Hondata k&N SRI base map
Fg2_k20_baawaa
Re: How safe to redline a Hondata k&N SRI base map
You will have to check the AF ratios to make sure they are safe and that you are not getting knock.
- CalibratEd
- Contact:
If you post the calibration and a datalog I can take a look and let you know how the car is running.
- Ed
- Ed
Instagram: calibrated.tuning
