External Wideband pinout
EFhatch
Post by EFhatch »
Hi there, i have in the shop another FN2, always used OEM lambda sensor, this time i will add an AEM sensor, never deal with FN2 for adding an external sensor but noticed it's possible. Just asking if you can confirm what pin is EGRlift, i found it's B-02 but found another EGR pins as B29 and B18pin.
Thanks in advance.
Re: External Wideband pinout
The pins are listed in the help file at: https://hondata.com/help/flashpro/ecu_connectors.htm
You cannot run closed loop from an aftermarket sensor. It is for datalogging only.
EFhatch
Post by EFhatch »
Thanks for info. it's not worth adding an wideband. Thanks again!
