I'm looking some help on a tune for my 2013 si.
right now I have an afe takeda intake, plm 3in catted exhaust and a 3in invidia exhaust.
I plan on rbc swapping and a bigger throttle body and bigger injectors soon. So I just did a stock re flash and the car is running good, should I leave it where its at till I get the other upgrades or tune now? I'm also very new to this tuning software. Thanks!
Help with a tune
- CalibratEd
- Contact:
Re: Help with a tune
For now the Hondata calibration is ok. Just make sure the car is running safe. Later on when you swap the injectors you will need a custom tune unless Hondata has a base calibration you can modify with the injectors you will upgrade to. If you are a DIY person use Hondata basemaps and modify them otherwise a custom tune is ideal.
-Ed
-Ed
Instagram: calibrated.tuning
Thanks, that's all really helpful. I am a diy person and trying to learn as much as I can on this side of building.
As far as I can tell everything is running fine I have no CEL's and drivability is normal and it seems like I made a little power, I did a few 3rd gear pulls but haven't beat on it and I haven't drove it real hard at all the past two days.
If I were running too rich or too lean wouldn't that throw a CEl? Or should I be monitoring for that?
Thanks again.
Thanks again.
- CalibratEd
- Contact:
I suggest you check the AFR at wide open throttle.Mswigart wrote: Sat Jul 20, 2024 6:14 am Thanks, that's all really helpful. I am a diy person and trying to learn as much as I can on this side of building.
Thanks again.
- Ed
