Temporary Idle Setting
web35
Post by web35 »
I need to set the idle temporarily at 2500-3000 rpm to check the oil level in a Kraftswerks supercharger system. When I read about live tuning, it appears that this is possible but I don't want to overwrite any of the calibration. I understand that the computer has to be in the loop but this "help" statement is confusing to me.
" eg if an ignition table value is 20° when the calibration is uploaded, and via live tuning you edit the calibration to 24°, then the ECU will reset the ignition to 20° if the vehicle ignition is cycled. However, if you have the FlashPro connected to the vehicle, then FlashProManager will recognize a 'key-off key-on' event, and will upload all the changes to RAM."
By default the Flashpro has to be connected to the vehicle.
Knowing my goal, can you offer a method, aside from a second person to hold the throttle, to accomplish this with the Flashpro?
Re: Temporary Idle Setting
You will need to have 2 people to hold the throttle and monitor the oil level.
