KManager 4.6.1
ky13
KManager 4.6.1
Post by ky13 »
I just bought a K swapped EM2 and am trying to connect to pull the calibration. I can connect via bluetooth from my phone and laptop, but from KManager on that same laptop (4.6.1 version) nothing ever shows up in the bluetooth device list. Anyone else having issues like this?
Re: KManager 4.6.1
ky13
Re: KManager 4.6.1
Post by ky13 »
Spunkster wrote: Fri Aug 02, 2024 11:01 am With everything plugged in and the ignition in the on position, go to the Help menu and click on “send feedback”. Include a detailed description of the issue.
That option is grayed out for me currently. The USB based connection doesn't work (according to the previous owner of the car), so I think I may be dead in the water. The car itself runs perfectly fine, I just want to pull a copy of the calibration for my records.
Re: KManager 4.6.1
What is the serial number on the K-Pro board inside the ECU?
ky13
Re: KManager 4.6.1
Post by ky13 »
Attached
KPro-4 57567
37820-PRB-A07
Re: KManager 4.6.1
If the previous owner said it was not working, then it sounds like it is damaged and would have to be replaced. This is no longer under warranty.
Send an email to support<at>hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
ky13
Re: KManager 4.6.1
Post by ky13 »
Spunkster wrote: Fri Aug 02, 2024 1:09 pm If the previous owner said it was not working, then it sounds like it is damaged and would have to be replaced. This is no longer under warranty.
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Sent. Thank you!
