S300 I Analog Inputs
TB123
Post by TB123 »
Was the analog input (0-5 VDC) setup removed from the software for s300 I? I recently downloaded the software from the website and found that the Analog Input tab is greyed out and states, "V2 and V3 only".
Re: S300 I Analog Inputs
Nothing was changed. The legacy Analog1 and Analog2 are still there.
TB123
Post by TB123 »
I figured this out. I will post the steps below to access these settings because it's not easily found in the Help Contents.
1. Access the Analog Input conversion table:
Options -> Settings
2. Rename sensor through Sensor Setup:
Sensors tab -> scroll down to Analog1/Analog2 -> right click (or double click) -> Properties
