Vtec not disengaging low load/ wideband lambda.
2007-2008 Fit
08FitSport
Post by 08FitSport »
I upgraded the camshaft to a delta 272 regrind. Crusing at 75-90 mph the engine stays in vtec low load. What can I control with adding wideband to the ecu? Can I change the Target lambda at cruising and idle to leaner then 14.7?
I changed the vtec window to:
lower 3800 upper 4500
vtec window pressure
rpm 3700 4000 4200 4800 5200
.886 .572 .403 .403 .222
08FitSport
Re: Vtec not disengaging low load/ wideband lambda.
jeffreestar wrote: Sun Aug 04, 2024 8:53 pm
08FitSport wrote: Sat Aug 03, 2024 1:39 pm I upgraded the camshaft to a delta 272 regrind. Crusing at 75-90 mph the engine stays in vtec low load. What can I control with adding wideband to the ecu? Can I change the Target lambda at cruising and idle to leaner then 14.7?
fnaf game
Adding a wideband oxygen sensor to your ECU will help you monitor the AFR more accurately and make better tuning decisions.
I am a tuner I understand that. But seems like the ecu in the fit will not allow you to run a leaner mixture then stoich in closed loop with the factory primary o2. My question was will adding a wideband for closed loop operation allow you to run leaner mixtures then stoich.
The last reply was from a spam bot.
There's a lot of logic in the ECU which is fixed to target stoichiometric.
08FitSport
Hondata wrote: Mon Aug 05, 2024 6:38 am The last reply was from a spam bot.
Even with wideband lambda? Why is my car staying in vtec at cruising speeds? 70-80 mph?
Without the calibration and datalog showing the issue, it is hard to speculate.
08FitSport
I’ll post up very soon. Have to data log it as I think I maxed out the factory injectors
08FitSport
Here is the calibration and datalog. Vtec engages at its set point then stays engaged at cruising speeds. turns on and never turns off.
08FitSport
forget to attach files
Let's pick a point in the middle of the datalog. 4000 rpm MAP 66 kPa.
The VTEC table has 57 kPa (0.572 bar) at 4000. So VTS will be on.
08FitSport
Hondata wrote: Tue Aug 13, 2024 8:13 pm Let's pick a point in the middle of the datalog. 4000 rpm MAP 66 kPa.
I figured it had something to do with vtec pressure window. Thanks for the help. I will raise the map pressure so it stays off when crusing.
