Upstream or Downstream o2 Sensor for closed loop
Evan214
Post by Evan214 »
Hey,
It’s been a while since I’ve looked at my smanager and and am currently not near my laptop, but I believe Im currently running closed loop with a wideband voltage target. If I ran a narrowband for closed loop would that be more efficient? I find my AFR’s at idle/low load a little inconsistent.
If so should I order upstream or downstream narrowband?
Thanks for any input!
Re: Upstream or Downstream o2 Sensor for closed loop
If you have a wideband then running closed loop with it should be the best option.
