FA5 Supercharged launch limiter
Jmags01
Post by Jmags01 »
When down loading tunes with boost capabilities you loose the launch disengauge speed and the full throttle shift option. Is there a base tune out there that has those capabilites?
CalibratEd
Re: FA5 Supercharged launch limiter
Post by CalibratEd »
Post the file you are using. I am not sure what you mean by boost capabilities.
- Ed
Instagram: calibrated.tuning
Jmags01
Post by Jmags01 »
In the available boost base tunes the Launch speed limiter for MPH disengauge and flat foot shifting go away in the Rev Limit options. I attached one of each base files. In the rev limit section you will see the differance.[attachment=0]launch disengauge speed and full throttle shift available.
CalibratEd
I am not sure what is missing. It seems Launch speed limiter for MPH and flat foot shifting options are available in both files provided.
- Ed
Jmags01
Post by Jmags01 »
Thats odd cause it doesnt look the same on my end.
Jmags01
Post by Jmags01 »
This is what i see on any of the MAP base tunes.
4.2.3 26 Feb 2024
Jmags01
Post by Jmags01 »
Thats the version Im useing 4.2.3 feb 2024
Your software is out of date and needs to be update to the newest version.
https://hondata.com/software?route=info ... nformation
Jmags01
Post by Jmags01 »
I downloaded the new software and it didnt change the issue that im having. It did add a new mod drop down and thats about it.
The calibrations you have posted show the correct things when opened.
When you re-install the software, make sure that everything is checked when installing it.
Jmags01
Post by Jmags01 »
I uninstalled Flashpro and made sure all boxes were checked for all vehicles when reinstalling. Still see the same thing, MAP based tunes dont have the same rev limit options.
Jmags01
Post by Jmags01 »
And it would probably help if i didnt originally post two of the same files. Here are the differances in files.
What is your FlashPro serial number?
