Kpro4 (white) Digital input / output wiring
oliversok1
Post by oliversok1 »
Hello,
If using any or the inputs (VSS, ETH, etc.) would the ground input/output need to be wired and grounded?
Re: Kpro4 (white) Digital input / output wiring
No, that ground is just there for inputs that require a ground. It is connected internally to the ECU ground, and is only suitable for low current.
oliversok1
Got it thank you for the quick response.
