Lambda overlay not working.
blownintegra1
Post by blownintegra1 »
Hadn't tuned the car for a few years, want to install turbo and injectors.
When it asked me to upload the new version, which seems to work, the lambda overlay doesn't populate.
It seems to show the AF when running, but I can't see it to try to tune.
I've tried stock tune and played around with the settings. You can see the table highlighted in pink while running, but no numbers.
What am I missing?
Re: Lambda overlay not working.
Post your calibration and a datalog showing the issue.
blownintegra1
I've tried all of these, and none are working.
Go to the Options menu and then go to settings and on the Lambda Overlay and make sure that all the conditions are set to that they are being met as it is showing correctly here.
blownintegra1
K-Pro 4
53164
rev24
blownintegra1
if it's displaying for you, but not for me, can you send me a screenshot of what you have checked and/or parameters??
There's only 2 options (in closed loop apply fuel trims), calculate for each cam angle.
Otherwise you've got the parameters. I left them alone and tried changing them, but nothing showed. If you'd tell me how to post a screenshot, it's pretty simple.
attached is the image
blownintegra1
Perfect, Let me try these parameters and see what happens.
thanks!
