Lambda Overlay Glitch
WestminsterClub
Post by WestminsterClub »
I see a lot of talk about lambda overlay not working and the plotting but not showing value. The attached is what I got to work for me.
https://streamable.com/2j79bq
Value don’t show up. Make the sampling rate really low. .01 it should populate values. Than go back in and set it to your like 1 or .5 and it should show your values.
Hopefully this can be addressed and this will help others
Re: Lambda Overlay Glitch
Can you describe the behavior so we can look at this?
WestminsterClub
Hondata wrote: Fri Aug 09, 2024 7:28 am Can you describe the behavior so we can look at this?
So here I have kmanager open 4.6.1
I open I calibration
I open a datalog
Plot somewhere in the datalog
I select overlay
The overlay is not showing.
WestminsterClub
Solution
This is my lambda overlay setting untouched
I than change it to .01
It shows the overlay numbers and percentages
Don’t want it showing .01. So I got back in and change it to 1 which is a good transition delay
WestminsterClub
This is a PRB ecu in a 05 s2000 with an f series engine
Did not have the same problem when trying this is k series.
WestminsterClub
In a k series file I select the lambda overlay selection and it populates and I don’t have to make any changes
What wideband are you using?
Can you post the calibration and datalog showing the issue?
WestminsterClub
Spunkster wrote: Fri Aug 09, 2024 9:24 am What wideband are you using?
This a AEM Wideband 30-0300.
Calibration and datalog attached for your review.
4-23-24 Calibration Pulldown.kal
4-23-24 drive.kdl
Change the number of samples to 1 and it will display
WestminsterClub
Spunkster wrote: Fri Aug 09, 2024 10:55 am Change the number of samples to 1 and it will display
Even when I adjust the sample to 1 it will not display. I'll upload a video
I still have to adjust the transition delay lower (.01) than adjust the acutal amount (1) for it to display.
WestminsterClub
This calibration and datalog were made with old software. Download and install the newest version and reupload the calibration and make a new datalog and see if that works.
You can also set the min cam angle to -30 in the settings for the lambda overlay, since you are not using VTC in the S2000
WestminsterClub
New calibration and data attached. I also set the min cam angle to -30.
Flex Fuel Street Drive Final.kal
93 Octane Final Run.kdl
It still doesn’t pop up when selected the first time. My current work around is to switch between display lambda values, Display fuel adjustment values sensor overlay. Doing so a few time pops it up.
There appears to be an issue that it is not initializing, but if you go to the Options, Settings and then Lambda overlay and click ok, it should display.
I have let our software engineers know about this.
