Wideband AEM Honda Cr-Z soft
ramzes_ttt
Post by ramzes_ttt »
Hi all!
I'm building a project based on a Honda CR-Z 2010 ZF1 MT JP car.
LEA engine built with KingTec forged pistons and connecting rods, Garret M24 turbocharger from RB26DeTT, 440cc Subaru injectors, map RDX.
So, during the setup process, I encountered the problem of incorrect readings from the 1st O2 sensor when going to boost after 3000 rpm. In this regard, we installed an external wideband lambda probe from AEM 30-0300, but encountered a problem in the Hondata software for the CR-Z; unfortunately, there is no way to switch the AF display to a non-standard lambda probe, as for example this can be done in the Honda Fit software. In connection with this question, is it possible to somehow open the item for selecting the input signal of the wideband lambda?
Re: Wideband AEM Honda Cr-Z soft
I'm sorry, but this is not an option for the CRZ. It can only use the OEM wideband.
