FlashProManager 4.3.3
FlashProManager 4.3.3 (16 Aug 2024)
  • [FK2/FK8/FL5/DE5] Added CANFlex support
Download here
https://hondata.com/canflex-10thgen-2.0
https://hondata.com/canflex-11thgen-2.0
Rodrigosantos
Re: FlashProManager 4.3.3
Post by Rodrigosantos »
Hello, pop and bang for Fk2 is not working, the overun fuel is working but not the retard table
Please provide your calibration and datalogs and an explanation of what driving modes you were using when testing.
Rodrigosantos
Already sent it by email!
Using sport mode or normal mode the ignition on deceleration is always 7/8 degrees, no matter what retard do you put in the table! I’ve tried some retard values and nothing is working! Tried stage 1 and stage 2 pops and nothing change in the ignition. It’s like the ecu is not assuming that table! I don’t know what strategie you use for this table but I think some other table in the background is correcting the values! Hope you understand!
Thank you!
Without a datalog and a matching calibration and an explanation of the driving mode used for the datalog I can't address this.
Rodrigosantos
I send it by email the calibration the datalog with r mode and explanation of the problem, check your email
Rodrigosantos
R mode
Please datalog on the FlashPro - the datalog does not have enough resolution.
And also provide a corresponding datalog in standard mode.
Rodrigosantos
hello,
i hope this time is good
thanks
KT7788
Post by KT7788 »
FB:
Comfort + R mode
Fuel delay - Working. if add too much (Example 2 sec delay), the car feels like choke/ jerk jerk during decel not smooth.....
The POP and bang Function , seems like intermittent working
With selection set to retard 15 / 20 /25 , it seem that other table/function is preventing it to achieve the require result
- example if you drive/rev to 5k rpm , release the throttle, it should fall into decel zone with the set retard IGN
- seems intermittent working
Attach if the log file
- please pardon me if the log file is no good...
- aleast i try
KT7788
Post by KT7788 »
KT7788
Post by KT7788 »
The pop and bang *Live Function is working ?
the intend is to *live adjust the parameters but seem like not working
Removing FK2 pops and bangs until we have a better chance to test this.
KT7788
Post by KT7788 »
Sad... please don't give up.
Doing great. Abit more here n there will reach the goal
Cheers
high718
Post by high718 »
Recently installed my CANFLEX kit on my fk8. Was initially on the sirimoto kit. At the time of install I was at 44% ethanol as per the innovate gauge. On my hondata app and iPhone on the canflex kit starts at 49% ethanol and as I drive the percentage drops to 6-8 ethanol. I am currently on the latest flash pro firmware 4.3.4. How/what can I do to get the ethanol percentage correct.
