P0134 Error Code
ares650
P0134 Error Code
Post by ares650 »
This past two weeks I have been getting the error code 'P0134 O2 Sensor CKT No Activite Bank1 Sensor1', every other day. I have stock exhaust, stock cat, greddy turbo kit, and the KPro. In the K-Manager software I do not have the CHECK on Disable P0134. What do you think is causing this CEL to come ON? :?:
Do you have the OBDII functions disabled?
ares650
Post by ares650 »
Hondata wrote:Do you have the OBDII functions disabled?
Yes I do, Would these matter?
The ECU uses the secondary o2 sensor to monitor the promary o2 sensor. If you disable OBDII functions then after a certain number of driving cycles the ECU will decide the primary o2 sensor is bad.
So, don't disable the OBDII functions unless you need to, otherwise disable P0134 as well.
ares650
Post by ares650 »
Hondata wrote:The ECU uses the secondary o2 sensor to monitor the promary o2 sensor. If you disable OBDII functions then after a certain number of driving cycles the ECU will decide the primary o2 sensor is bad.
So if I would uncheck the OBDII, then I shouldn't have anymore problems, right. When I put in my test pipe with 3in exhuast then I should disable the OBDII and P0134, right.
Great, Thank You.
Correct. Good luck and have fun.
ares650
Post by ares650 »
I did as you said and the error has come back twice since my last post, what do you think of that?
Do you have the secondary o2 hooked up? Do you have a cat?
ares650
Post by ares650 »
Hondata wrote:Do you have the secondary o2 hooked up? Do you have a cat?
From my frist post.....Yes, I do have the secondary O2 hooked up and the stock cat in the car.
I think you will need to look at why the P0134 error code is being generated as per the manual. Check A/F ratio while driving as check that the short term trim is not getting excessive. Otherwise I suspect that unplugging the 2nd o2 sensor will stop the P0134 error code occuring.
