S2000 Kpro Wiring
chudomino
S2000 Kpro Wiring
Post by chudomino »
I have a 2000 Honda S2000 with a Kpro v4. I was trying to run a signal to the ECU's E22 brake switch so I could have a switch for the launch control but I cannot locate a diagram for which wire is running into my ECU. The Hondata website shows it is on the connector e22 pin and is the a32 on the s2000, but I cannot find a diagram showing which connector it is.
Re: S2000 Kpro Wiring
The info at https://hondata.com/help/kmanager/ecuconnectors.htm is correct. It is on the A connector pin 32.
chudomino
Post by chudomino »
Spunkster wrote: Fri Aug 30, 2024 4:01 pm The info at https://hondata.com/help/kmanager/ecuconnectors.htm is correct. It is on the A connector pin 32.
Thanks, got it working.
