CANFlex Issues
DE5_Now
CANFlex Issues
Post by DE5_Now »
I am having intermittent issues where the CANFlex will throw a check engine light while driving. The indicator lights on the can adapter will flash red and green. This happens every so often while driving and seems to be getting more and more prevalent. The check engine light will go away on its own and the can device will resume flashing green based on the enthanol content. I have checked and reseated all connections. Thoughts?
Re: CANFlex Issues
Do you have a datalog of when this is happening?
DE5_Now
Re: CANFlex Issues
Post by DE5_Now »
Well i took two trips of 20+ minutes and no issues. Usually its good in the mornings and the afternoons it is an issue. But today it was the opposite.
I have logs but no CEL popped up.. so not sure if those are any value.
Re: CANFlex Issues
Check the wiring while it is running and see if you can get the check engine light to come on with moving it a certain way or in a certain place.
Did you install this yourself or was it installed by someone else?
How is the wire form the sensor to the EBCAN box routed?
DE5_Now
Re: CANFlex Issues
Post by DE5_Now »
I went to the outside and through the door trim. Which was shown as an option.
Re: CANFlex Issues
Have you checked the 2 wiring harnesses?
DE5_Now
Re: CANFlex Issues
Post by DE5_Now »
I didn't inspect the harness preinstallation. I will pull it and look this weekend. Also I will re route cable to firewall.
The install directions are confusing with a mix of 10th and 11th gen information. 11th gen install is done by removing the car battery and not with windscreen.
Re: CANFlex Issues
Both 10th and 11th gen installation are best done by removing the battery and going through the wiring connector near the clutch. Be careful when creating a hole in the grommet as it is easy to damage the factory wiring harness if you poke something through. I'd never recommend going around the door trim.
Inspect all the wiring and also connectors for recessed pins. Seems like you understand the use of the LEDs for diagnostics already.
notafl5
Re: CANFlex Issues
Post by notafl5 »
Did you ever get this fixed? I am having the exact same issue.
D-Rob
Re: CANFlex Issues
Post by D-Rob »
I also have a client experiencing the same condition, specifically using software version 4.3.4.0.
My personal DE5 hasn't encountered this yet, and I've driven it quite a bit. As a side note, I haven't flashed my own vehicle with 4.3.4.0 at all yet, if that matters.
Re: CANFlex Issues
Please update to the new software and see if you have the same issue.
Re: CANFlex Issues
Send an email to support <at> hondata.com with the following and I will get more information and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread
Puppers
Re: CANFlex Issues
Post by Puppers »
Joined just to add a comment that the problem exists when the FlashPro unit is unplugged from the OBD port.
I reflashed my calibration and have left my FlashPro plugged in and the light is a blinking/happy green light now.
Notorious9i6
Re: CANFlex Issues
Post by Notorious9i6 »
Same issue with the check engine light appearing and disappearing when the flashpro is unplugged. Plugged in the cel never shows up.
I am also running issues where my DE5 exhaust valve is acting weird. Sometimes it works, sometimes it unresponsive where it just stays doesn’t open or close and is “stuck”. All of this starting happening after installing Hondata canflex.
Re: CANFlex Issues
Contact support with your details.
