Dual connections possible?
danielthenerd
Post by danielthenerd »
Is it possible to have two connections to my s300 at the same time? I have a digital dash which uses the USB connection and I'd also like to connect via Bluetooth for data logging or minor tuning. It seems when I try to do that it kills the other connection so my digital dash stops working. Is there anything I can change in settings to make tool connections possible?
Slow is smooth. Smooth is fast.
Re: Dual connections possible?
danielthenerd
Sorry for the delay, car is currently loaded in a trailer and took a minute to get to.
53024 is the ser no
danielthenerd
Here are the info tabs for about and Bluetooth.
What I notice is that if I connect via Bluetooth the USB connection gets cut off. My digital dash is connected via the USB, so I don't want that.
danielthenerd
@spunkster?
You will only be able to connect one at a time not both, at the same time.
