Lamda or AFR not reading in tables
reallyflyguy
Post by reallyflyguy »
2007 TL Type S MT
So I've tried to search this up and I haven't found anything that has solved my issue.
I have been trying to clean up my fuel map for driveability and noticed I'm only filling a small area of the table with my AFR or Lamda. I've tried switching between both. I'm using my stock sensors (corrected) and this has always worked for me. I am currently using the latest BETA software too.
I've looked at the sensor overlay and the lamda overlay and I'm wondering if I've changed something in the past and didn't realize until using it this summer.
Can you help?
Re: Lamda or AFR not reading in tables
Post the calibration as well as a datalog showing the issue.
reallyflyguy
here's my latest data log and calibration.
Thanks for looking!
reallyflyguy
I tried to populate the table as much as possible. Most of the missing readings are medium to full throttle
It seems to be populating the areas that it is tracing on the tables.
reallyflyguy
Really? Under wide open throttle it didn't show any AFR on the table
Check the over lay settings to make sure that you are within the parameters for it to show up.
