Autotune missing items to check/off
Francisco G *999
Post by Francisco G *999 »
Hi, I would like to ask for any information you can possibly pass along my way due to having an issue with my autotune being my second effort. I started off by making an autotune file and everything worked correctly until i started a new map to autotune. So the problem is when selecting online, "Select live tuning tables" i am not getting to see Low fuel & High fuel for me to continue on selecting and that is the issue because i know the first time i made my autotune file i was able to select those two and also select WOT lambda adjustment high & low, this would go by only needing to select Low & High speed cam fuel tables. So the issue continues after selecting Low & High speed cam fuel tables i see a 70% highlighted in green in the live tuning memory bar, but scrolling down to see the boxes that are checked off i can only see WOT lambda adjustment high & low having the little box checked, I try and find low fuel & high fuel to be able to see and check or uncheck it but it is not showing on the list. I also tried unchecking the 2 WOT and the % goes to 64% but i look down on the list and nothing at all is checked to see a 64%. I tried everything to be able to see Low fuel & High Fuel in the list for me to be able to lick the box and have it checked add add the 2 WOT but because i cant get to see the Low & High fuel listed i am not able to continue to be able to make a autotune because when i start to autotune i only get the Lambda Graph and not the fuel table graphs and i find that to be a problem because i am trying to tune the fuel tables. Like the first time i did it, it worked perfectly and this time im not sure what is going on or what i need to do to be able to start off a live autotune map once again without any problems? May anyone know of this issue and know how to resolve it. I already tried deleting all my map files and also the datalogs and start a new calibration & also upload an new untouched calibration but it all ends the same me not being able to see my high & low fuel tables. Please help?
Re: Autotune missing items to check/off
Post the calibrations in question.
