S660 Data is reflected incompletely.
Tiana
Post by Tiana »
I changed the VTC table for my S660 MT 2015, but it didn't work.
To find out the cause, I set everything to 50 degrees except for idle and throttle off.
Then, when not at full throttle, it works at 50 degrees, but when at full throttle, it works at the same angle as stock.
Which item should I adjust to solve this problem?
Re: S660 Data is reflected incompletely.
Post the calibration used as well as a datalog showing the issue made with that calibration.
Tiana
Post by Tiana »
Thank you for your reply.
I have pasted the data I initially used, the data where I experimentally set it to 50 degrees overall, and the log data for both.
I didn't take logs, but the 50 degree data was correctly set to 50 degrees except at full throttle.
So I think the data flash was successful.
I look forward to your advice.
Thank you.
Email support <at> hondata.com and I can send you a link to download software to try and see if this helps.
