VSS issues on kpro
Locoguero87
VSS issues on kpro
Post by Locoguero87 »
Using a VSS sensor on rear driveshaft ABS ring (50 tooth).
I wired the sensor to the VSS plug that was on the rear Of transmission. So when testing it out cluster is way to high and so is kpro mphs. I calculated the pulses per mile and entered 200336 per mile on the alternate speed input tab and uploaded it to car. Speedometer still doing same thing but kpro isn't registering any speed and will trow a VSS error code and get stuck showing 3mph untill I reset it.
37820-PRB-A05
Kpro V4 60859
Locoguero87
Re: VSS issues on kpro
K24a2 swap into 98 civic
Post the calibration and a datalog showing the issue.
