P0101 error code , engine stalls , high fuel
Type_Raichu
Post by Type_Raichu »
New Motor install crate
new PRL P700 turbo with FBO PRL intercooler,PRL Hvi stockm charge pipes, exhaust catted, front pipe
21 ctr
UPDATED to 4.3 latest version Sep 26 2024
checked box, checked mod list still rough idle, heavy fuel smell, wont stay on
daily driver and only car right now, :(
Re: P0101 error code , engine stalls , high fuel
When you datalog are there any errors?
Type_Raichu
Just the p0101
Also unsure how to attach data logs here in this forum
Basically stays at 14.70 in all revs
Checked wiring. Checked grounds, checked fuses, cleaned MAF sensor, checked all boost leaks possibilities,
The only thing I'm thinking is replace the MAF sensor
Which I just ordered a new PRL race MAF And a brand new filter to eliminate that possibility
Type_Raichu
Ok. I'm at my worst with stress and can't think clearly
I'm stuck at 14.7 after new sensor installed and running poorly.
Running out of time for Dallas show and can't get this working.
P0101 is disabled and still throwing code. All boost leaks potential issues are checked and good.
All mech issues checked and just stumped.
jeffx
Post by jeffx »
To attach files you can simply drag the files directly into the browser while posting in the thread. There's another way to attach logfiles and calibrations: while posting in a thread, there is an 'Add files' button just below the message box and once you click that, you simply navigate to the folder with the files you want to post and select them from there. Post your calibration as well.
Type_Raichu
Ok, time to close this thread .. or let ppl know. Always check your wiring when your gut says something isnt right. Took me several days and bought a few items to eliminate any issues
The freaking LAF on top of the turbo was only partially plugged in. SMH .. I tugged in the sensor so many times but the snap didn't fully click until I spent hours searching every other possible connection. A simple snap on the top of the connector and ...boost was back. No codes.
SMH. Always check your connection.
Thanks for all ideas as it always comes down the the simplest solution
