Power steering issues with vss->css
Colecgg
Post by Colecgg »
2004 Civic Si,pnf kpro v4, k24a swapped, pnn4 6 speed swapped with css, no converter for dash yet.
Hello,
I have installed a new transmission and repinned the plug for css and feeding the sensor 5 volts. Uploaded the map with css speed sensor selected. Speed is reading good on kpro and vtec is still working properly. My issue now is my electric power steering is cutting in and out along with the eps light.
Is this due to me not having a speed converter installed and is there anything I can do in kpro until I get the converter?
Thank you.
Re: Power steering issues with vss->css
