Question regarding Hondata type
ivanchikhani
Post by ivanchikhani »
I have a hondata installed in an Ariel atom 3 . Came as is from factory . I’ve bought flash pro and successfully modified the map . Now , I’m trying to connect my DASH2 to the ECU , and it gives me two options:
Hondata K4PRO
Hondata S300
Now , I haven’t got a clue as to which is it and the wiring is specifically tied to either one .
Pictures of my ECU . Also , CAN Output - Hondata Protocol must be set to (500kbps) . Can this be done with flash pro ?
Thanks !
Re: Question regarding Hondata type
I'm sorry, but that is not compatible with the FlashPro.
ivanchikhani
I’m sorry , it IS compatible with a flash pro because I’ve been remapping the ECU with a flash pro .
That dash is not compatible with the Flash Pro as it does not have an output for aftermarket dashes.
