Fk8 Hondata flash pro registering problem?
edvin777
Post by edvin777 »
Hi, I’m trying to register my Hondata flash pro, but I don’t why the green check mark doesn’t appear where it says is register, I don’t know if my Hondata flash pro is register correctly or I’m doing something wrong, thanks.
Re: Fk8 Hondata flash pro registering problem?
It appears to be registered. What are you trying to do that you are having a problem with?
edvin777
Post by edvin777 »
Thank you for replaying, the reason why I’m asking is because the green check mark doesn’t not appear on mine, and on others hi flash pro it always appears the green check mark, here an example
Beyond that what is the problem you are having?
You are looking at the jailbreak window. If you want to know if your FlashPro is registered look at the Registered Owner window.
