FlashProManager 4.3.6
FlashProManager 4.3.6 (28 Oct 2024)
  • Firmware updated to version 249
FlashProManager 4.3.5 (25 Oct 2024)
  • [2017+ Si, 2022+ Si] Added CANFlex support
  • [2017+ Si, 2022+ Si] Fixed launch control mods
  • [FL5] Added 66V-J03 (part number 66V-J04)
  • [2015+ S660] Changed X axis to MAP for fuel and ignition tables
  • [2022+ Civic] Added support for 2024 model 64A-AG2 US
  • [2018+ Accord 1.5 MT] Added launch control parameters
Download here
KT7788
Re: FlashProManager 4.3.5
Post by KT7788 »
May i check if the FK2 pop n bang issue is settled ?
It has been removed for now.
Gmoney79
Re: FlashProManager 4.3.6
Post by Gmoney79 »
I updated to this version and when I plugged my Flashpro in it said it needed to be updated and also that my previous calibration was from an old versions and ask to update it so I did. After that uploaded something to my ECU. I previously had a base tune so I believe I uploaded the same thing just with the never version on the Flashpro. My ECU did all the same things as it did when I did my first tune (the base map).
hit the download button on the online tab and then hit the upload button on the flashpro tab under calibration for primary. Car seemed to drive fine and no lights. My question is did I do it right and do I have to upload each time I update my flashpro?
I new to all this and will eventually get it professionally tuned one I get my exhaust. So any advice would be appreciated.
Thank you!!
Any time you update the software you need to open your calibration and upload it to the ECU again. It sounds like you have done it correctly.
Gmoney79
Post by Gmoney79 »
Ok cool! Thank you!
bryanzeng
Post by bryanzeng »
for fk8, how can i set the pop and bang stage 1 for sport mod and pop and bang stage 2 for R mod?
You cannot have different settings for that based on the mode the car is in.
William.Y
Post by William.Y »
Hi ,may I ask , is FlashPro support FL5 ECU NO. 66V-U030? If not, how to make it support?
Another FL5 , JDM version, Chassis No. start with FL5-120, can FP support it ?
Many thanks.
Has the ECU been jailbroken?
Probably not supported at this time. What is the ECU part number on the chassis code FL5-120?
William.Y
Post by William.Y »
66V-U030 not jailbreak yet.
Send us the file.
William.Y
Post by William.Y »
can't attach the file here, where should I send ?
send to support <at> hondata.com
William.Y
Post by William.Y »
Thanks! ECU file sent. Normally, how long it take ?
