97 auto prelude needing hondata
lawtonprelude
Post by lawtonprelude »
I have a 97 prelude. It's an automatic (triptronic). I had to do a JDM transplant. Blew the H22A4. Now has a H22A. I don't want to swap tranny yet.Can I use Hondata with an Automatic tranny? If so which unit should I use and what other mods do I need? Also, I used the old tranny from H22A4 and swapped distributor, throttle body, oil pump, and crank trigger to complete the swap. ECU is still OBDII, but I have the OBDI here too. Please help with this problem. Hondata helped my freinds RSX Type S so much, now I need it.
You can only use a Hondata if you convert to a manual tranmission.
