Graph limits (vertical axis)
DrPhyzx
Post by DrPhyzx »
Greetings,
I'm trying to benchmark a new cooling setup, and want to view some datalogs where I graph:
- Engine speed
- ECT
- VSS
So I can see how it is behaving on the road. The problem comes when I want to graph this. Even when I have data with temps over 200F, the graph display sets the Max for the temperature scale to 200F, so I can't see the behavior around the fan turn-on point: it's off-scale. Is there a way to set the vertical axis limits in the graphs? Alternately, is this a bug that can be fixed? (Seems pretty easy to set limits automatically that will show the available data.)
Thanks,
Tim
Re: Graph limits (vertical axis)
Right click the item in the sensor list and click properties, and you can change the min and max values.
