New to FlashPro and can't find answers
Dreamer
Post by Dreamer »
Hey All,
I got my Type R unlocked and got the flashpro recently. I had some questions if anyone is able to help.
I'm currently running the CivicR-2023-Us-2-93octane Calibrations.
By default it ticks "Fuel -> Pump Gas(10% Ethanol) does this matter? I've never used E85 but I was planning on getting CANFlex down the road. I was googling around and checking and apparently some cars can just take 10% max out without a flex fuel kit. Not sure if this applies to this specific portion. Otherwise I was going to stick with the Pump Gas (0% Ethanol).
I was also interested in the Multi-Tune, I don't see any tutorials on this. Ideally I'd like to put a "valet" mode in this for when I need it but I don't want to "flash" the car before hand so it's stuck in Valet mode. Is there a way to run this normal tune for 93 and I go into Multi-Tune and lower the boost by gear. However how do I figure out what the values mean and how to tune them down?
Thanks in advance. I'm a noob :(
Re: New to FlashPro and can't find answers
Most fuel in the US contains some ethanol, especially during certain times of the year. You do not need Canflex for 10% ethanol.
Have you read the info in the help file for multi-tune: https://hondata.com/help/flashpro/multi ... multi-tune
Dreamer
Post by Dreamer »
hi! Thanks for the answer I've gone and flashed my with the fuel with 10%
Yes I have read the multi tune - so in the basic calibrations you can limit MPH to like say 40.
With Multi tune - Boost per gear if I turned that own to 0 and left everything else default this should leave the basic tune right? Cause I don't want to mess with it but it looks like it goes from like 0 to 5.0 something and all i really want is just a valet mode and regular mode :(
Multi-tune is probably not the best for a valet setting as all they have to do is put it in a different mode.
