Running base map in high altitude
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
Polkaman
Post by Polkaman »
Looking to pick up the Flashpro and run the stage 2 base map for my '18 2.0, just had a couple questions to see if hondata or ktuner is my best path.
I live in Colorado and most gas stations only offer 91 octane. Don't plan on getting the car custom tuned for a while, is running the base map on 91 recommended? Only other mod I have in mind is a mishimoto intake.
Re: Running base map in high altitude
What elevation are you at?
Polkaman
Post by Polkaman »
About 5500 feet
That will be fine.
You will probably not see the same gains as at lower elevations and you should be ok to use 91 octane fuel.
Polkaman
Post by Polkaman »
Thanks a bunch, appreciate the quick replies. Still pretty new to the tuning world, is there anything I should keep an eye on when driving the car? Such as knock, etc
Look at the knock and AF ratio.
