Wiring AEM oil pressure gage to S300 V1
mjalaly
Post by mjalaly »
Just to clarify, if I want to datalog oil pressure throughout a run can I wire the AEM oil pressure gauge to either B6 or D12?
From what I understand only the brown wire should be pinned to B6 or D12. Can someone confirm that?
I will also check to make sure the right capacitors are there.
Re: Wiring AEM oil pressure gage to S300 V1
You can, but it is for datalogging only and cannot be used for any protections.
mjalaly
Post by mjalaly »
Understood. Can you confirm the wiring is correct?
No, the white wire must be connected as it is the signal.
mjalaly
Post by mjalaly »
Thanks!
mjalaly
Post by mjalaly »
Brown to B2? Or does another ground work?
It may not need a signal ground. Try it without it and see if it reads correctly.
